Jauge qui déconne
Page 6 sur 7 Précédent  1, 2, 3, 4, 5, 6, 7  Suivant
Re: Jauge qui déconne
Message par Bipbip le Mer 15 Juil 2015 - 20:26
Un post US qui traite du sujet de long en large :
http://www.1130cc.com/forums/showthread.php?t=106786&page=22
Il y a une note de service Harley concernant ce problème de jauge : Service Buletin M-1249
Ce document donne les instructions suivantes :
Fuel Gauge Service Bulletin M-1249
7/13/2009
Purpose
The purpose for this bulletin is to inform dealers the fuel level sensor part number 75210-07B is obsolete and part number 75210-09 will retrofit 2007 and 2008 models (except VRSCR) with the required fuel gauge recalibration utilizing Digital Technician.
NOTE
This was done to eliminate a part number only. There is no need to replace the fuel level sensor unless an issue is verified.
Models Involved
Fuel level sensor 75210-09 will fit 2009 and later VRSC models without need for calibration update.
If replacing a fuel level sensor on 2007 or 2008 VRSC models, 75210-09 will retrofit, but will require a fuel gauge calibration using Digital Technicican.
When fuel level sensor replacement is required on 2007 and 2008 VRSC models, the fuel gauge must be calibrated using the update available in Digital Technician, located in the "Vehicle Set-up" in the "Toolbox" icon.
NOTES
* Some variance can be experienced with the fuel level sensor readings dependent on temperature of fuel, temperature of fuel tank, etc.
* If replacing a 75210-07, 75210-07A or 75210-07B fuel level sensor, with a 75210-09 fuel level sensor, the fuel gauge MUST be recalibrated using Digital Technician to ensure proper fuel gauge operation. If fuel level sensor 75210-09 is installed on a 2007 or 2008 VRSCA/D model without fuel gauge recalibration, it will cause inaccurate readings and the actual fuel level will be approximately 1/8 tank less than what is displayed on fuel gauge.
* Starting in 2009 model year, the motorcycle MUST be moving and receiving vehicle speed input in order for the instrument module to properly update the fuel gauge. This is to prevent an inaccurate reading while the motorcycle is on the side stand. After fuel refill on these models, it is normal for the low fuel light to remain on and the fuel gauge to indicate a lower than actual fuel level until the motorcycle is moving.
* Because the ultrasonic fuel level sensor accuracy diminishes slightly as the fuel temperature increases, temperature compensation is applied and the fuel gauge may display less than the actual fuel level to prevent fuel runouts at high fuel temperature. At higher motorcycle/fuel temperatures, when the fuel level indicates empty, it is normal that less fuel is required to fill the fuel tank than at cooler temperatures. It is also normal to see a slight increase in fuel level indication after the motorcycle has cooled.
* DO NOT attempt to install an older version of the fuel level sensor assembly into 2009 model year motorcycles. 2009 models MUST use 75210-09.
Bipbip
Message par --mamatt-- le Mer 15 Juil 2015 - 20:37
sur la mienne ça le fait aussi.
pour faire simple la jauge c'est un peu l'ancien systeme des chasses d'eau...
le flotteur galère à se mettre en bonne position surtout quand on vient de faire le plein.
Après avoir fait le plein je roule quelques kilomètres je coupe la bécane sur off et je la remet sur ON et la plupart du temps le niveau compteur redevient correct.
Pas de quoi s'alarmer, il suffit de regarder les kilomètres parcourus ça coûte nettement moins cher que de se faire "arranger" pour être poli chez le cons.
--mamatt--
Son Age : 31
Ville et C.P : 08400 vouziers
Message par Bipbip le Mer 15 Juil 2015 - 20:51
Il faut compter une centaine d'euros pour le capteur chez Jersey, 30 min à une heure de bricolage et ... une bonne bière
Bipbip
Son Age : 43
Ville et C.P : RP
Harley-Davidson : Pro Street
Message par Shura le Jeu 16 Juil 2015 - 8:41
Heu... ils parlent également d'un re-calibrage électronique (modif dans carto ?).
Son Age : 40
Ville et C.P : 30-GARD
Harley-Davidson : Manche Nocturne Spécial Collec
Message par Bipbip le Jeu 16 Juil 2015 - 9:39
Le recalibrage concerne les modèles avant 2009
Bipbip
Son Age : 43
Ville et C.P : RP
Message par cochise le Jeu 16 Juil 2015 - 20:52
et qui peut le faire ce recalibrage ?? je suis concerné avec mon 2007
cochise
Ville et C.P : Plouisy 22200
Message par --mamatt-- le Jeu 16 Juil 2015 - 21:03
Egalement avec mon 2008...
--mamatt--
Son Age : 31
JAUGE
Message par christ6259 le Ven 17 Juil 2015 - 21:13
Bjr
j'ai le même problème avec la jauge d'essence, la moto à 3 mois est ça beug
même quand je met le plein la jauge reste dans le rouge
christ6259
Son Age : 47
Ville et C.P : 62
Harley-Davidson : Vrod Special 2015
Message par cochise le Ven 17 Juil 2015 - 21:47
fonce chez ton cons ça passe en garantie .
cochise
Message par Bipbip le Ven 17 Juil 2015 - 23:29
christ6259 a écrit:Bjr
Il faut avoir rouler un peu pour que le niveau change, sinon l'information de la jauge n'est pas traitée.
Si ça persiste à rester dans le rouge alors que le réservoir est plein, retour en garantie. Pas de cadeau.
Bipbip
Son Age : 43
Ville et C.P : RP
Message par Silver Bullet le Mar 21 Juil 2015 - 14:32
A 120 €uros (80£) le sensor fuel level (24) chez Jersey HD, ça fait mal au fût ....
Surtout si c'est pour obtenir la même daube et devoir le re-changer très prochainement
Je préfère laisser le dysfonctionnement et me servir du compteur kilométrique comme repère ....
Mais, si un membre du forum (aguerri en mécanique) trouve une solution sans remplacement du fameux sensor, alors là   Je suis preneur
Bon ride
Silver Bullet
Ville et C.P : Lyon 69 666
Message par Hipusnitu le Mar 21 Juil 2015 - 21:20
Silver Bullet a écrit:A 120 €uros (80£) le sensor fuel level (24) chez Jersey HD, ça fait mal au fût ....
Bon ride
y'en avais un mais il ne répond pas...
Hipusnitu
Son Age : 39
Ville et C.P : Sud 77
Message par cochise le Lun 27 Juil 2015 - 20:05
ma jauge avait été prise en garantie et elle a tenu plusieurs années . ça vaut peut-être le coup
cochise
Message par Hipusnitu le Lun 27 Juil 2015 - 20:07
Trop tard pour moi la garantie
Hipusnitu
Son Age : 39
Message par cochise le Lun 27 Juil 2015 - 20:10
ils parlent français chez Jersey HD ?
cochise
Message par Silver Bullet le Mar 28 Juil 2015 - 9:39
I don't know ...
Non, je ne sais pas. j'ai passé commande (Cornets US) via leur site web uniquement ...
Mais je ne pense pas qu'ils puissent aider techniquement parlant sur une problèmatique de jauge sur V ROD
Silver Bullet
Message par Papoum le Mar 28 Juil 2015 - 10:11
Pour que la jauge indiquant l'autonomie restante quand on passe sur la réserve soit à 95% exacte, le bon truc est, de temps à autre, de faire le plein réservoir quasi vide.
La jauge se réinitialise alors et arrête de dire des grosses conneries.
Truc indiqué par un mécano Harley.
Papoum
Son Age : 80
Ville et C.P : Grimaud 83310
Message par cochise le Mar 28 Juil 2015 - 10:26
ok . c'était pour voir . je passerai bien commande mais j'ai peur de me planter dans les ref . l'anglais et moi ....
cochise
Message par Silver Bullet le Mar 28 Juil 2015 - 14:24
Si c'est le capteur de niveau (Sensor fuel level) (comme expliqué plus haut) que tu veux changer ce n'est pas compliqué : C'est la pièce 24 (Ref. : 75210-09) chez jerseyh-d.com
Silver Bullet
Message par cochise le Mar 28 Juil 2015 - 15:39
oui mais j'aurai voulu avoir confirmation que le modèle ref 75210-09 corresponde bien à l'année de ma bécane car il y a des modèles avec et sans flotteur
cochise
Message par Silver Bullet le Mar 28 Juil 2015 - 16:07
  Effectivement tu as raison, en 2007 le système était différent et la référence serait : 75210-07B (pièce 25) qui remplace les précédentes 75210-07 & 75210-07A
Silver Bullet
Message par cochise le Mar 28 Juil 2015 - 16:12
ha ben tu vois pourquoi j'hésite un peu avant de commander . en tout cas merci d'avoir fait des recherches
cochise
Message par Silver Bullet le Mar 28 Juil 2015 - 16:37
Pas de problème si je peux rendre service... Par contre avant de commander quoi que ce soit moi je veux être sûr que le problème vient uniquement du sensor et pas d'autres éléments qui composent cette véritable usine à gaz qu'est la jauge à essence du V ROD
Silver Bullet
Message par cochise le Mar 28 Juil 2015 - 18:00
oui tout à fait et à en juger par le nombre impressionnant de jauges qui déconnent, je trouve lamentable que HD continue de monter le même matériel (made in japan sans doute! quoi que)
je suis sûr qu'ils peuvent faire plus simple
cochise
Message par Silver Bullet le Mer 29 Juil 2015 - 9:23
  Peut-être pas plus simple, mais surtout plus fiable
Silver Bullet
Message par dardagnan le Lun 28 Sep 2015 - 10:58
Adonf c'est pour toi
dardagnan
Son Age : 40
Harley-Davidson : night rod 2008 et fxs 1977
